Head lights / day time running lights
TODD WILSON
5
2
32
ANY INFO HELPS ‼️
Installing new heads lights and i want to sync them with my day time running lights does anyone in the group know what wire i should splice for it to work ? ( what them to both work when i have my turning signal on on and hazard lights )
I assume you bought aftermarket headlights with halos or U DRL integrated in them, am I correct?
If yes do you want them to be on any time the key is on or only when the engine is running?
Yes, I have the aftermarket headlights with the halos. I want them to work when my hazards are on and when I’m making turn signals, I want them to be in sync.
Did you get a data sheet with the headlight bulbs?
Need to know how much the halos will draw, you might need relays because the T/S or hazard circuits might not carry the load. Might have to use solid state relays if the mechanical ones have a slight delay. Will require some experimenting.
You will get the signals from the light blue (Left) and dark blue (right) wires coming through the lighting half of the C100 connector.
