crowconcepts said:In my setup, which is still a mismatched bunch, my small heads and huge exhaust , 3 1/2 oval, my long tube headers are too much breathing room. And shorter smaller headers would probably help my low end.
Not to argue, just to discuss, I've heard the opposite as far as length goes. The longer the primary and collector of header, the more torque. With the opposite being true for horsepower. I do, however, agree with you on diameter.
I would say if you have small heads that yes, especially with a 3 1/2 inch exhaust, that smaller primaries and a longer overall length would help scavenge during overlap and give you a good boost to your low end torque. Many people think that the bigger the better because at high RPM so much volume is being moved. At low RPM, overlap between the intake and end of the exhaust stroke can cause the exhaust gases exiting through the exhaust port to create a huge suction on the intake port and help to pull in an incredible amount of air. If optimized through keeping exhaust velocity up, this can lead to a great increase in volumetric efficiency. As far as I understand the theory anyways.
