Looking For 1 3/4" headers
Ernest
1,145
1,916
Texas
For gbody chassis of course.... particularly for my 1979 malibu.
Anyone know of any that are a direct fit or install with little modification... i'd like to get the ceramic coated type, but if i had to ding and ping it, the finish in those areas would be disaterous, or just touch it up with some high temp silver paint. 😉
My plans are to get a sbc 383 crate engine as a replacement for my ZZ4... im currently getting quite a bit of silver and gold bearing material in the old oil and some forbiden fine silver gliter from the oil filter when poured out, but luckily, the engine along with the transmission is still running well IMO, no smoking or knocking, just slight pinging off and on, even with 93/10% ethenol gas.
No history on the driveline(ZZ4/700R4), so i cant say how old everything is... figure worst comes to worst, if i cant find a decent set of headers, i'll just have the ZZ4 short block part rebuilt(.030 over) with flat top 2valve releif pistons and ARP hardware through out and use better flowing 64cc aluminum heads(AFR 195cc) and a slightly more aggresive camshaft over the stock(208/221 - .474/.510) installed one to keep my power brakes and i'll just reuse my 1 5/8" rusty looking ceramic coated headers and keep the dual 2 1/2" exhaust alone, get the 700R4 rebuilt with upgraded internals with a possible 2400rpm stall converter and definately keep the 3.73 posi out back.
I have no idea of the brand my current headers are... same look and design as shown in the link, they fit perfectly in my car w/o issue, i only wish a 1 3/4" exact design was available.
Technically... i could use 1 5/8" headers on a 383, it would help more in the low and midrange area, but not much for top end.
I dont plan on racing it on the street or at the track, none around here in an hours radious anyways, i have yet to go over 3k rpm to this day with my ZZ4 to this day, its just a cruiser and i open it up slightly just to help keep the plugs clean since its not a daily driver, but honestly, 1 3/4" prefered for the larger engine if possible.
The plan is to get uncoated headers, ping and ding them up if i have to just get them to clear everything i need, have an O2 bung welded in on both headers, then get them ceramic coated, best way to do it IMO.
  • Wow
Reactions: melloelky
I don't know what you currently are running for a cam but regardless of what route you go on the engine I wouldn't put anything but a roller cam in either engine. JMO
The ZZ4 crate engine uses a roller block, 1pc rear main seal, L98 corvette aluminum heads(58cc/1.94-1.50) 10:1cr, and a hydraulic roller camshaft.... 208/221 - .474/.510 112LSA for specs, runs great, 17hg @ 800rpm idle, and i do plan on going with another roller block and hydraulic roller camshaft setup.
Reactions: 565bbchevy
American racing headers. Cry once and be done with it. Fit and finish is top notch! Even though mine are 1 7/8 headers you get the idea..
ALERCH.... $1600 headers, im cry'n already.
Coltrane... very nice, but after reading some of the reviews, seems the driver side fits just fine, but the passenger side requires some finess to fit, what issues, if any, did you have?
One thing to consider is the AR headers are made of 304 stainless steel and they are having a memorial day 10% off sale so you can cry just a little less.
