Looking for 18 inch Wheels for My El Camino
rwolf15241
125
16
It's time to work on my El Camino. I 'm Looking for Wheels for My El Camino. I want to run 18x8, 18 x9.5. posted is the style I'm looking for!!
I will not use wheel spacers, any suggestions
I plan to use a Ford 9inch in the rear.
and a 2006 LS2 6 speed under the hood
84cutlassjuggalo
512
6
Morell PEI Canada
fast wheels have some awesome ones for a low cost
bigblockfrank
208
4
mt.vernon, ky
i have 18x9 on rear i have a 5.25 backspace i had to use a 9 mm adapter. i would try to stay around 4-4.25 rear and 4.5 up front. the rear still may rub outer rear lip. heres a site to compare different size tires and wheels. i used it , i would have to say its a good guide to go by. http://www.rimsntires.com/specs.jsp a adapter is a little different than a spacer, heres a web site i bought my hub and wheel centric adapter. they center there self over the axle hub, and then the wheel center it self for tight fit over the adapter. i had to use extended wheel studs. here the site http://www.motorsport-tech.com/wheel_adapters.html . use a 1980s s10 2wd.
MrHernandez
556
9
Jackson,TN
Type Hurst Wheels in ebay search, theres a nice set, seller is out of elburn, il I believe, free shipping too. Have them in black and in gold also
