Looking for a part
would one of these give me a fuel distribution issue?
should i just get a dual carb one?
Wilson makes top of the line custom sheetmetal intakes but there is a pricetag to match. The intakes usually start at around $2000 depending on design and go up from there, either you are extremely generous or didn't relize the actual cost of these if they were considered affordable you would see them on everything. These are really designed to get every bit of horsepower out of your set up and to also cover combinations that are not available as a shelf item.
Yea i was deff unaware of their pricing. I saw the dual tunnel rams without carbs going for 350-400 which is fine, i figured one of theirs should be the same, but nope. Im probobly just going to go with the dual carb tunnel ram.
Yeah, I figured you were thinking it would be around the same price as a cast tunnel ram.
What size and brand engine is this for? If it's a Chevy I see nice used ones on Craigslist all the time mostly small block occasionally big blocks.
