Hi. Looking for some guidance. I have a 1983 Hurst Olds. All stock. She'll start right up when cold. Idle is high so the choke is working. After about 5 minutes the engine idle starts to drop then stall. If I try to re start immediately, she will not start. I'll try pumping the pedal, open throttle, no throttle, nothing. I have to wait about 5 minutes before she'll start back up by pumping the pedal a few times while she initially starts back up. At this point I have to keep hitting the throttle because she wants to stall. After a few more minutes I can stop hitting the throttle and she'll idle. Idle will be pretty smooth. I can let it idle for 5-10 minutes and no problem, smooth idle, good throttle response. If I shut the car off, wait a few minutes then start again, she'll start but will want to stall so I have to repeat and keep hitting the gas until the idle smooths out again. This is what I have done:
Replaced the carb gasket (base)
Replaced all vacuum lines
New plugs, wires, cap, rotor, coil
Checked timing (20 degrees)
Replaced fuel filter
Replaced o2 sensor (was original sensor)
Vacuum holds steady just under 17hg when idling fine.
I believe I don't have a vacuum leak between the intake and the heads. The idle doesn't shoot up when I spray carb cleaner.
I did get code 44 a few times, on and off. I did not replace the EGR valve. I did not check the TPS. I cannot adjust the idle mixture because the plugs are still in.
I'm thinking it's something internal with the carb.
Any feedback would be greatly appreciated. Thanks! Andy
