Looking for mechanic in ontario
dft
29
2
Hey guys. I'm just about through with my resto (1979 Monte Carlo), but I am having issues with what I believe is a ground. My turn signals all flash when I indicate and when I turn on my headlights the do not even flash, also my battery keeps losing charge when I drive (not sure if it's related or another issue in its self). I have the dash off and tried to look around but I can't seem to figure it out. Does anyone know of any mechanics in ontario that would be familiar with gbodies?
Thanks.
it should be easy to find someone in that area. From what you describe it sounds like the turn signal switch may be toast.
for the battery drain have you checked the alternator to see if it's working...you can take the alternator off and have it checked at partsourse
