ive put together a little 79 malibu for 1/8th mile foot brake bracket racing below i will post all details on car....i have had it to the track 2 weekends in a row the car has done good overall but is lacking in the launch/60ft areas -
details-
approx. 33-3400? full body/interior racing buckets/deleted heater/ac box/removed inner bumper structure
350 .40 over
11.1 compression
aluminum 58cc 210int. runner heads
488/507 lift hyd. flat tappet cam adv.duration .288/.297
1.6 crane full roller rocker arms
performer rpm air gap intake
650cfm double pumper no power valve jetted 76 square
msd billet hei dizzy timing totalled at 37 degrees
powerglide trans w/manual valve body
3800 converter will hold on footbrake at 2500rpm and flashes around 3600rpm
4.56 gears spool with 28/10.0/15 slicks
90/10 shocks on front 50/50 on rear
so far after approx 12 passes the best et was 8.10/60ft 1.78/84.24mph with a most average pass of 8.16/60ft 1.79/83.30mph ihad a lil larger converter in the car first few passes and it ran 8.15/60ft 1.76/83.06mph this converter was a 4000 but wasnt working properly ....it seems to me the car is doing fairly good on topend but the launch is very weak and 60fts are slow compaired to other similar cars i run with ive got a couple that are running almost the same gear /converter running 1.58-1.64 60fts running high 7s in the 1/8th but these cars are running 350th and 400th trannys it seems there is a big debate over 350th/powerglide in bracket cars some are telling me my car is way to heavy for glide and others say i wont see no difference i do know there is a huge low gear difference from my 1.82 glide to the 350th but some say the glide will pick the lost time up from the higher gear mid track when your only making 1 shift instead of 2,,,,from what friends watching the car are saying the car does nothing when coming out of the hole it doesnt seem to me as it starts pulling good until it gets moving im stuck thinking myself its either transmission or fuel? .......i know this car has more in it just looking for insight on what others think open to all opinions......
details-
350 .40 over
11.1 compression
