This is my 2c on some of your problems
Your duration a .050 is low that's is one problem you have with slowing down after 6500rpm.That cam is only good for about 6000 then it starts to die off,Your going to need a cam with more duration and a closer lobe Separation.for duration in the upper 250s and the lobe less then 110 something like the cams i put in the post
and this is your cam spec
http://www.summitracing.com/parts/sum-k1107
this is what i use in sbc and even on the street
http://www.ebay.com/itm/3-Solid-Cam-Lif ... 27cbc1bd48
the 6000-6500 area is about as far as i like to turn a 350 anyway ....this car is mainly a race car i drive it on occasion im not a fan of solid cams as ive only had a couple and never got the knowledge on them as i have for hyd. cams ive got a solid roller in a car i just bought im tuning with it now maybe ill get the hang of the solid lifter cams with it.....as of now the cam im leaning to the most has a 108 lobe sep. and 246/253 duration @ 0.50 over 110 lobe .235/.243 @50 i have now
here are the specs on my cam im running
http://www.skipwhiteperformance.com/det ... =110041-10
