The steering clolumn in my "85 Regal is loose. The outside collar will rotate with the shifter when I use the column shifter. It also feels like the part of the column that is closest to the wheel is loose too. It wobles around back and forth. (its a tilt column) (Note there are two separate issues here, in two different spots) Is there are away to tighten it in either spot? Is the whole thing shot?
Thanks for any help.
