CUTLASS Lost all power, fuse box help?
maxi426
Sep 20, 2018
81
77
S213 is a splice. You would have to untape the dash harness to find it. I think G104 is screwed the dash frame with a 10mm headed sheetmetal screw.
84 W40
562
764
No illustration, just tells you the location.
g0thiac
938
581
Well, I can't get to the factory ground splice unless I take my dash apart, which I am almost about to do if I can't get my dash lights back on.
Heres my symptoms.
I have 12V coming in no issue. There is no interior lights in this car, so I can't tell if those were working.
However, I have a voltage drop of around 2 volts whenever +12v is applied to what I believe is the main pink wire that I believe. I also connected the brown one.
This should in theory, be connecting accesories on as if the key moved forward.
As I have cut the wiring off the steering column for the ignition, I guess someone used duct tape for the factory splice 🧐😂😂😂
As honestly I don't really care if I have it hot wired- still no dash lights though which makes no sense to me. Actually when I bought the car, I wanted to have a switch toggle on all on 12 volt accesory if possible.
g0thiac
938
581
I can have the high beam indicator on my dash to work but no headlights still, and the lighter to have a smoke from all the crazy electric problems but that's about it like wow
Ran also, the ground from where the radio was and the diagnostic port, to the battery in case the wires from G104 were damaged- since it is a common ground.
So I have no idea what to do, other than take apart the entire dash to get to that ONE harness ffs 😒😭😭😭
g0thiac
938
581
So. The problem has been fixed.
And I bet that most of you mother****ers would never guess what it was.
It was the battery itself. It read a normal voltage, and would operate the rear lights without no issues there.
But when, you tried to use the dash or anything other than the tail ones it would show an INSTANT voltage drop, as if there was a short circuit.
g0thiac
938
581
I am glad however, I did check my wiring anyway, because after having both fusible link wires, fall apart from the connector, I knew more wires that sat closer underneath this car would be damaged.
As when I wiggled my headlight wires, it would dim and go very bright.
So I replaced the wires. Plus, like the other Oldsmobile, I used my own fusible link, and wired the vehicle to the battery.
Did some upgrades too, because I also re wired the fusebox, deleted my dimmer switch and made the headlights no longer run with +12V without no accessory power.
I also have upgraded my wiring to the ignition and the grounds on the headlight too 👀👌👌👌
g0thiac
938
581
After spending the week fixing the wiring, the vehicle starts better, and all lights as required :)
g0thiac
938
581
Sooo then the issue was not just the battery....
Agencylife Bingo GIF by MX Player
It was, if I had decided to not go the extra mile, since I was already in the vehicle anyway.
Now, could I have left the old wiring in? Of course! My main concern was getting the lights to work, so I could pass a safety.
But then, someone would point out half assing effort, so uh...
www.youtube.com/watch?v=n1Pb6HjdS-U
