Basically what the title says. I have a 700r4 for my ls swap. I was thinking of installing it behind my 350 for now which will require me to cut the drive shaft. Im planning on using the spohn mounts because I want AC and I want to keep it down low in its original position. My fear (kind of) is if I install the 700r4 now, when I do the swap will the trans move forward or back causing me to have to do the drive shaft over again.
Btw I believe I have to use the sphn mounts because the plate style mounts will interfere with the compressor. Atleast that's what Ive read.
