LS swap wagon edition
Tberstler4
11
12
I’ve seen some great write ups in the ls swap category but I’d like to know who’s done a wagon ls. Is there any differences or issues you ran into? I have a 79 century wagon that im pulling the Pontiac 301 and turbo 350 out and will sell those. Going to do a 5.3 with a cam 862 heads and a turbo with a th350 and a 8.8 rear end. Which in tank fuel pump would accommodate that with a wagon stock tank?
nawlins-tim
286
59
New Orleans, LA USA
NO replies?
Wraith
1,602
4,764
DFW, TX
On a wagon using an in tank fuel pump is the biggest problem but not so much with the aftermarket sandwich/drop in style pump, other than that standard LS G-Body swap stuff applies. As far as the 8.8, that also has some hinges depending on Mustang or Explorer.
Also, FYI, the Wagon's forum might just be one of the most unused forums here.
Tberstler4
11
12
So I got an 8.8 out of a mustang and the trick chassis swap kit. Also ordered the Astro van in tank sensing unit and going to order a walbro 450 pump for it.
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Other than the fuel tank, the EFI conversion will be the same. You may want to rig up a baffle, or make absolutely sure not to go under 1/4 tank to keep from uncovering the pickup during accel/decel/turns. Holley makes a series of pickups called Hydramats. May have magnets to keep it in place, but it serves a virtual baffle, sitting on the bottom of the tank. The price may inspire some more creative thinking, but, it's a solution for the non-standard tank. No G wagon ever came with EFI.
