sx455 said:
low mileage lq9 from a wrecked denali---1250.00
i opted for the carb conversion for simplicity ,edelbrock conversion kit---750.00
headers -----ended up using fbody camaro and doing a little tweaking----250.00
carb--- 400.00
motor mounts-adapters---- 150.00
trans adapter plate 150.00
This ia all the basic stuff tour gonna have to have to just get started .
I am doing just a conversion that is mainly for the strip with afew cruise nights added in and this thing has plucked my last nerve! custom grind cam kit with springs retainers ect---1000.00
electric water pump with all the braided lines and thermostat housing-800.00
without knowing more info hard to even respond to this thread, i didnt know if he was looking for one stolen, or what, to vague... anyhow, for others reading too...
the 6.0 (or even a 6.2 which I love) is an awesome motor...
but you can also get, with budget in mind and some performance:
2003ish 5.3
$500, with pcm and harness and good mileage
sell the accessories off it (complete intake, ps/brackets, etc)
-$200
total for motor
$300
buy ls1/6 intake, with rails/injectors and injector pigtails, which you will need to change on your truck harness
$200
LS1 (98-02 front accessories), if no ac, power steering pump/brackets, alt. brackets, water pump, idler, tensioner, balancer
$300
LS6 yellow springs (brand new)
$56
LS6 cam (5308)
150-200 depending on how patient you are
fuel system (wix filter, walbro inline pump, an fittings, hose, inlc braided etc.) from tank to rail
$300
motor mount kit (set back)
$70
adapter flexplate with longer screws for 700r/350 (or old style non electric) transmission
$53
re work your own harness, NO COST and easy to do
nice fuse box and relay set up
$100 (current performance can do this for much less though
computer reflashed
$75 incl return shipping
brand new stock replacement aluminum radiator with provisions for steam holes
$112
labor, do it yourself, cost of beers/liquid encouragement
$100
36" lokar throttle cable
$50
bto tv cable
$150
net roughly=
$2066
anything I missed, ask and ill add estimated price, or ill go back later and add, when i remember, but those are the basics
and that ls6 cam is a beast for the price, used roller cams usually stay in great shape and dont wear bad if at all with low mileage
cheaper than going carb (if you have the intake and injectors to began with) and inj is super easy to get to work
doing tons of research will save you tons of money and will be done right... I have done several of these swaps with my bro and am currently doing something with my project (a little less budget oriented though), so there are may people willing to help
$2066 isnt bad for a motor that will out perform a 350, it would cost more to rebuild a decent running 355, trust me. and there is money to be cut there too... but for a decent proj not bad... take off that ls1 intake/ls6 cam/springs/ etc. and it will be cheaper, the stock truck intake out performs the ls1 anyway... but may have hood clearance issues, if using a induction hood, like the one I have for sale, you dont have to do anything with the motor or accessories...
ElkyHolik87 said:
No offense buddy but you have a better chance of pissing on the moon when you throw the word "reasonable price" in any of those two equations. If it were reasonably priced to do LS swaps we all would. Nonetheless Ls1 deals are few and far between, but they are around.. Couple months back ran into a brand new 0 miles ls1 create motor for 1200. Good luck
depending on how much you do yourself and what you know, it can be done for a reasonable price... as sx455 said, depends on your definition...
