FE3X CLONE said:If the Beltech spindles are basically like the stock design, only with a drop then yes, you should be fine. You just need to cut the caliper mounting ears off the spindles and then drill out and tap two of the dust shield mounting holes to a larger thread size.
You can buy the caliper adapters or whole kits from Ed Miller at http://www.flynbye.com
