I have a 94 lt1 in a 77 Cutlass. Have a brand new Cutlass radiator, lt1 thermostat, & water pump, but coolant isn't flowing correctly. Does anyone know of a radiator made for the lt1 that will fit a 77 Cutlass Supreme? Any help is appreciated.
My mechances bled the system & hooked all hoses up when he did the swap. However, he also didn't install an overflow reservoir. He has a hose that's coming from the back of my engine (I believe heater core hose) ran to the overflow tip on my radiator. He says that this isn't my problem, though.Where did you connect hoses, and did you bleed the system?
I'll check on the cam to pump coupling. Thx fellas, I'm at a brick wall.They need to be bled at the thermostat housing, iirc. And, people forget to connect the cam to pump coupling when they change water pumps. Little black piece of metal....
