Lt1 in 78 malibu
JD was it you that's running the B Body water pump? I thought about running either B or Y body pump cause there is no oil cooler line. To minimize having to cap things off. Wasnt sure if that would create an issue with accessories lining up.
I have a spare b body water pump on the shelf but the fittings on it were not a perfect match (direction wise) for the molded heater hoses from the Z28. So i kept the Z water pump and removed the hose nipple for the oil cooler, threaded the hole 1/2” npt and screwed a plug in.
Reactions: Baker7888
Here is my lt1 caballero. Caprice accessories drive, water pump, and heater hoses. Z28 radiator , hoses and fans.
And here is my wagon with an lt1. Caprice accessory drive, water pump, heater hoses. Gbody radiator and top plate. Modified z28 radiator hoses. And a mechanical fan. This is a pic, not a video.
Love the swaps guys. Those that are running heater cores - are you using the restrictor valve on the supply (to heater core) line? Did anyone drill a small hole in their t stat?
I have been reading in various places the lt1 pump can do some funny things (airlock) when t stat closed.
No problems with the cooling system or heater system.
No mods in the factory temp tstat.
I don't recall if I'm using the factory restrictor. Both cars are covered in snow. I'll check my pics.
Hey baker7888, what are you using for power steering pump?
