Re: LT1 or Olds 350-rebuilt? Why?
You can reuse all accessories, I did a 403 swap in place of a 307 in place of a 307. -
I did a 350 Olds swap into 2 chevy trucks that had a sbc 350. You may need the 307 water pump to properly align the 307 pulleys on the 350. All brackets will bolt on to the 350 Olds like factory. The starter will work for now. A large body Olds starter or after market mini will eventually be needed. Your exhaust manifolds are probably tiny steel 307 manifolds, no good. The exhaust manifolds he has are probably early manifolds which have a different exit angle due to no catalytic converter. I would just get a new pipe put in to hook up and replace the converter with a straight pipe, if no emission testing.The conerter is probably plugged .
