LT1 swap
mr hyde
10
I bought a 1994 buick roadmaster donor car to transfer the motor and 4l60e trans in to my 1980 el camino. plan to keep it fuel injected and basically stock. I have pulled engine trans front accesories wiring and drive shaft. I plan on getting rid of this donor car this weekend if you can think of anything no matter how trivial please let me know before i get rid of the junker.
If it has the Electronic HVAC controls, they are worth pulling. PM me if you need more info, or check out my website.
Does anyone have suggestions on a pcm tuner? I am not looking to make major changes just eliminate vats, ac, shift points if possible on this set up. They only way i would want to get in to fuel and timing is if its way off which I know some of those minor changes could alter fuel and timing.
I would say the key bypass but then again that only came with the police cars let me know if there's anything I can help with considering I did one to my grand prix about a year n a half ago... pretty straight up swap for the most part... but ask and I shall tell buddy...
did the LT1 swap 2 years ago , but still carburated
Id like to put it EFI
Did you do the harnesss yourself ?
I've got a painless wiring harness in my cutlass I bought from summit racing I used just to hook nut motor up, I got the factory intake, injectors and all I want to carb my motor for my c10. I'm parting out my cutlass
