Malibu dash looking to convert 80 to 81 style
I did a heat only 79 Monte Carlo dash swap with an A/C dash out of a 86 El Camino. If you are using the non A/C set up which physically will fit behind an A/C dash you have to keep the back pocket from your non A/C glove box. They are different between the heat only and the A/C cars and must be used accordingly. Otherwise it should be a direct swap. I ended up using a 81 burl wood inlay for the passenger side and just added a section of black plastic behind the vent on the passenger side. Below are some not so detailed shots of the dash in the 79.
View attachment 214958 View attachment 214959
yes, i already new about the glove boxes being slightly larger on the a/c cars and not fitting the heat only set up. i actually also have a complete extra heat only set up stored away . complete with glove box, hvac control panel and harness.
Reactions: 79 USA 1
