DJLATIN said:so no one reproduces them? geezuz.85 Cutlass Brougham said:The lower door panels should interchange with later 2 door G bodies, as should the B pillar door opening trim piece you seem to need. The color won't match, but there is always dye. As for the quarter window trims, your best bet may be E-Bay as these are rare pieces that deteriorated very quickly even when they were new. GM's 70's plastics were even worse than their 80's counterparts for the same car as they seem to have been made of a material that is excessively susceptible to UV light deterioration. My advice if you find an intact set is to have them vacuum formed with vinyl by Just Dashes. This will restore the grain pattern to them and make the surface a material that will not break down quickly in the presence of UV light.
Have you tried OPG, I did the interior in a 79 last year and the guy had all new plastic trim for his.
