i just put a short tail th350 in the 81 Malibu and the spare drive shafts I have one from a el camino with th350 and wagon with 200 trans are too long any body know the proper length for a 2 door Malibu with th350 and 7.5 rearend
As long as it had a 7.5 with either a Th350 or Th200c it will work yes. Same length.Ok cool so one from a cutlass should fit?
Wagons do not have a different wheelbase. the only difference from the 2dr/4dr/wagons is the rear mounting holes on frame after the rear axle.. the elcamino is the only frame that is a different length/different wheelbase.El Caminos and Wagons have a longer wheelbase than a standard coupe gbody so they are longer. I assume you got a 6" tailshaft TH350. Any stock driveshaft from a TH350 coupe gbody or a Th200c coupe gbody with a 7.5 rear or 7.65 rear (monte SS, etc) will fit. I don't know the length off of the top of my head but I do know most driveshaft places only charger 150 or so to cut weld and rebalance a driveshaft. I'd say find the difference in wheelbases from a 1978-1987 el camino and a 1978-83 malibu and that'd be how much you need to have it shortened by.
Ah. My bad.Wagons do not have a different wheelbase. the only difference from the 2dr/4dr/wagons is the rear mounting holes on frame after the rear axle.. the elcamino is the only frame that is a different length/different wheelbase.
