gmachinzz said:It's interesting you have a true 2-speed Mark VIII fan....I have yet to find one....all of them regardless of the inspection plug are single speed. Ford used a series of power transistors in their VSF controller which varied the specs in several steps. If you ground the black lead and apply power to one terminal and then the other, you should be able to tell the difference in fan speed based on that-no change means its single speed no matter what else. I gave up on the relays for it as a result and instead I have been building resistor harnesses where each speed is resistored out to give you up to 4 fan speeds if desired....still relay activated through the use of temp switches, manual override and AC use.
Now, the RF24 fans are similar in design and while not quite as stout are still better than anything aftermarket-and for those I use 2-speed relays to simplify wiring. Dustin, I remember the DC Controls and Spal fiasco a few years back-I have not gone back to a controller since then either. If anyone needs help with the circuit wiring, let me.know, I have excellent harnesses to simplify wiring for these fans....some of the connectors and weatherpak terminations require the right tooling but some things you can build yourself.
