Master Brake Cylinder?
rubio9800
242
110
California
Hello folks,
Happy 4th!
Just got back from a cruise and it was a bit worrisome. When applying the brake it got so soft it went all the way down and the Brake dash light came on.
It went away few seconds and the brake feeling appeared to be normal. As i kept on driving now the brake feeling is either firm (most of the time) to spongy feely(slow to return)
I couldn’t see any brake fluid leaking, and there is fluid when i looked in the cylinder. Can’t tell if it was full or low, got changed less then a year ago.
Could it be the cylinder? Do not feel comfortable driving it now.
Thank you in advance
rubio9800
242
110
California
i took off the reservoir cap again, something just didn’t feel or look right when i did it the first time.
there is fluid but the rubber piece looks swollen and it’s hard to put back in
doing research i see this could be an indication of contaminated fluid?
Last year i did replace the brake fluid (at a shop) but didn’t think to open it to do a comparison.
Ribbedroof
4,903
7,003
Wellston, OK
The light coming on indicates a pressure imbalance in the system.
I would pull the rear wheels and drums to look for leakage at the rear wheel cylinders, then check the calipers at the front. Other things to inspect are the flex hoses at each caliper, and at the rear axle center section. If these have never been changed, do it NOW. Sometime, the rear wheel cylinders don't leak enough at first to show up on the backside of the backing plate or wheels.
Then I would check the steel hardlines...follow them back from the master cylinder to the distribution block/proportioning valve to each wheel.
While the master can sometimes internally bypass, in my experience, it's not common.
i once owned a Malibu that had a leak in the hardline that came out of the master cylinder. It appeared that a ham-fisted mechanic had managed to move the line to where the upper control arm managed to rub a pinhole in it at the bottom of the vibration coil.
CopperNick
3,357
3,018
Canada
Outside possibility that, if the car has one, your brake booster has gone bad on you. Otherwise the list above give a good summary of places to look and things to see.
-dw-
209
377
Central MN
The reason for the swelled cap seal and funky brakes is some kind of oil was poured into the master cylinder. Thats guaranteed death to any rubber seal in the brake system. Oil will be slick between your fingers and brake fluid will not.
Hurricane77
333
676
Ottawa, Canada
That is definitely not right. If the gasket looks like that, good chance the seals in the master cylinder are not is great shape as well. Even a chance that seals in the pistons and drums are gone too.
rubio9800
242
110
California
when i first got the car i had leaking wheel cylinders and were replaced. Also replaced the calipers.
i’ll be going to a shop later today, see how that goes
