81Regal said:It's not the speed that will kill a driveshaft or rear axle, it's the torque or ability to get traction. I would upgrade the U joints if you are concerned.
othtim said:Hi. I have an '83 Monte LS. I'm swapping in a new motor this week, and I'm planning on getting the engine dyno'd. I'm curious what the max speed the driveshaft can handle is. It is a TH350 transmission, stock '83 Monte LS driveshaft.
jrm81bu said:81Regal said:It's not the speed that will kill a driveshaft or rear axle, it's the torque or ability to get traction. I would upgrade the U joints if you are concerned.
There is still a problem with critical spped, you spin it fast enough and it will come apart.
Fwiw, I had my Malibu on a chassis dyno, ran up too 6000rpm in third. I had a th350 in it then so the driveshaft was also spinning 6000( minus convertor slippage. With the 2.41 gears and whatever tires I had at the time it ran up to 170 on the dyno.
larryo454 said:So whats is Critical speed????? For a stock shaft.I run a MT 33x 21.5 with 5.13gears and a th350 with a healthy 461bbc that i buzzzzz to 7000rpms on a stock shaft.The U joint is the scary part for me being so small.
Hi i have built a backhalf car with ladder bars and running mopar 8 3/4 with rich men pro gears and i know that the pro gears are not good for the street but thats it. O and the axle is back about an 1" from stock location and u can't tell the diff.jrm81bu said:larryo454 said:So whats is Critical speed????? For a stock shaft.I run a MT 33x 21.5 with 5.13gears and a th350 with a healthy 461bbc that i buzzzzz to 7000rpms on a stock shaft.The U joint is the scary part for me being so small.
It will vary, there is no set speed. It just comes down to how well it's balanced. Basically as rpm icreases the weight of the shaft itself starts to make the shaft bend, it can bend far enough to pop out of the transmission(in cases where there isn't enough of the yoke going into the tailshaft), or just put enough stress on the yokes and/or joints that they fail.
Yes the stock u-joints are a weak point if you have a lot of power, but critical speed doesn't need a lot of power, just rpm, think of a 3.8 with overdrive going for top end on a long highway, with a 2004r it only needs to turn 4760rpm(not saying it will do it, just an example) to match you driveshaft speed off 7000.
There was a problem with the newer Chevy trucks that weren't using a 2 peice shaft, people were turning off the speed limiter with tuners and the driveshaft would come out of them.
edit-And what rear end are you using that you have 5.13 gears and still have a stock driveshaft?
larryo454 said:Hi i have built a backhalf car with ladder bars and running mopar 8 3/4 with rich men pro gears and i know that the pro gears are not good for the street but thats it. O and the axle is back about an 1" from stock location and u can't tell the diff.
