Mini Starter Question? Tooth Flywheel?
if its an inline most of them have the dual pattern to go to the big flex and the small flex. staggered is like a stock one only made for one size. summit normally tells you the tooth count flex its for........
If it's a small block chevy you really only have to worry about two sizes: 168-tooth and153-tooth. You can ignore the rest if it's an sbc.
dude hit me up got to make this fast
tooth count is flywheel size. I forget off hand
when you get under the car you can see how the bolts are set up. or you can take out the starter and see what you have you could have both.
i think the older ones are straight
best to take a look
best to take a look
Sweet!! Me and Ghettoracingkid are working something out that he has lying around...
Hopefully it works for you. I have no need for it and hate having it laying around when someone could use it.
80ELCAMINOFLAKE said:
khan0165 said:
hey I remember you asking me about mine, from DBElectrical.com
I see you found one the same on Electrical.com
I'm happy with this starter, my engine is close to 11:1 comp, no cranking issues. I have a large 7qrt oil pan the flares out the sides, with headers, and it fits great
I know it's a cheap chinese part, but works well for a budget item
Thats a sweet pic..whats your tooth count? bolt pattern?
mine is a diagonal bolt pattern, with a 168 tooth flywheel
most of the old blocks were diagonal bolts, with 168 flywheels
Wow Khan what a difference huh... Lol... Thank u sir... 🙂
