motion raceworks operator 4l80e cable opening relocation ?
johnnunez29
238
53
so i have a rear exit manaul valve body 4l80e and am going to run a motion race works shifter. The problem is the stock hole in trans tunnel is at the front of the shifter. If i use that then i need to go from back of shifter to the front throught the hole and then back again to come forward and attach to the trans. Has anyone made a new hole? doesnt seem like a big deal im just curious if others have done this? also how did you re mount the center console? once i removed the stock shifter the from mounting bases are gone. Even worse the rivet nuts broke off. need to cover those holes.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
You could use a pedestal to mount the shifter.
