just as a double check, what oil pan is it?
regardless you should be fine, 7qts is about 2 over stock. plus i don't think they make a 7qt w/out a deep sump, just make sure the pickup clearance is correct.
also, when you use nitrous you need to make sure that there's extra fuel available. honestly i don't know what that takes on a carb, since it's not a constant use thing.
