Motor Mounts: I know I've asked this before.
The holes should be drilled for it already.
Ok, I remember a lot of holes on the frame, but I didn't know if they matched up with the 4 holes on the chevy mounts.
Its easy to figure out. Just line the hole in mount to the top very front hole the rest will fall in place but you will only use 3 holes. The bottom one uses the slotted hole. The other hole on mount will over hang the frAme on bottom front side.
i have the mount that bolts to the motor but they came out of a silverado does that make a difference or not i tried bolting up today with horrible results well not so much horrible half horrible i got the pass. side bolted but the driver side is about a 1/4" off and its annoying me with a passion
Truck mounts are different then car mounts.
