That slight a difference will not cause any mechanical problems I can think of, but there may be another issue. Check to see if the oil pan is touching the frame, or if the headers do. If so, this could cause issues with these components over time as fatigue sets in and causes cracks. The engine and trans need to be isolated from the car's structure so that vibrations do not break parts. Also, be sure the positive cable to the battery is not touching the brake lines on the crossmember. I did not on one swap, and the engine's vibrations wore through the insulation, and arced to ground. This cut the brake line into 3 pieces, and even plasma cut a hole in one header tube! Needless to say, I am now quite anal about checking lines and wires for contact points!
