Easy will be determined in your preparedness.Will this be a easy job
One thing I can add is any 80 and up Cutlass, regal, or Grand Prix with a V-6 231 Buick motor will have the mounts you need. The 231 and 350 Buicks share a lot of parts. After 1980 only Buick made 6cylinder engines. It shouldn't be to hard to find a set of those mounts. Someone else here can probably tell you the correct location and holes to bolt them to. As for the transmission, you should use a g- force cross member because I'm sure you will want dual exhaust.Will this be a easy job
