Mould neutralizing/removal?
clean8485
2,891
2,247
Ontario, Canada
Anyone here know of a product or a cleaning solution that might neutralize or remove mould on interior fabrics and surfaces? Any homemade "secret recipes"? Thanks in advance.
8 parts white vinegar and 2 parts water....adding the water makes the vinegar stronger. That solution will kill the mold and remove it.....and good on fries if you have any left over
Plus once you get the mold out and dry out the interior, you can put in some small bowls of cat litter or rice to absorb any moisture in the future.
Might want to try a steam cleaner or vacuum steamer as well. That combined with the recipe Steve suggested I would think should do the trick. Don't forget to crack all the windows if you go that route as well as waiting for a warm day to dry everything out nicely.
