Mounting Hardware
SupremeSpeed
596
802
GA
I bought a pair of F41 bars, and I'm in need of the mounting hardware for the rear. I have an 88 Olds Cutlass Supreme Classic. It has after-market lower control arms. They are the tubular kind that are adjustable. But I would be willing to get a pair of box control arms if need be. 20170402_155353.jpg
I bought a pair of F41 bars, and I'm in need of the mounting hardware for the rear. I have an 88 Olds Cutlass Supreme Classic. It has after-market lower control arms. They are the tubular kind that are adjustable. But I would be willing to get a pair of box control arms if need be.View attachment 63658
You can still use tubular lca's.Just looks like yours are not drilled for a sway bar.Alot of boxed control arms have solid bushings and are not adjustable and geared more towards drag racing with weld on relocation brackets for adjustability.Just get a set that is drilled for a sway bar,some nuts,bolts,washers and possibly some sway bar shims if nessasary.
Thank you for your reply. Ive been looking into getting some but before I did I wanted another option. I had an idea to upgrade the suspension but I did not ask for advice before doing so. I appreciate your help.
Check out Southsidemachineperformance.com in Indianapolis...they have alot of sales going on now and should be able to get a good lower set fairly cheap.My son and I just got the G body ultimate handling package for both our g bodies,really nice stuff.
Thanks alot! I'm definitely looking into them. Maybe I will purchase other items also.
