mebe007 said:how is the limiter adjusted on those modules? so will i not really see any gains at all with the msd box? is really just one of those things where you can say that you have it? like i said i have a brand new mallory hei setup (billet dist, module, cap, rotor, and coil)
mebe007 said:how much does something like that run and is $140 a good deal for a 6al box?
there is usually i dial under the cap, i had a pertronix one and thats how it was donemebe007 said:i meant adjustment with the module style in cap limiter. put thanks for the input, always appreciated
mebe007 said:next question if i can talk the guy down with the box, how can i test for it working properly, so i am not buying an inoperable piece of junk
Bonnewagon said:I test on a spare distributor. But it must be hooked up to a batt and wired up correctly, I use alligator clips and pre-made test wires. I keep the coil/cap seperated from the dist and have a big ground wire held an inch away from the coil output that the rotor rides on. It might be too much for you to rig up, but that's how I do it, and that spark WILL ZAP YOU if you let it. So be carefull.
