Here's my small block Olds build list......
350 Olds gas block bored 4.1250 with torque plate, decked to 9.300"
330 Olds steel crank, stroked to 3.500, machined for Cheby rods
Eagle, Cheby 6.0" 500 gram h-beam connecting rods
J&S 5 main halo girdle
ARP head studs, main cap studs, connecting rod bolts, etc.
Custom CP forged pistons 12.5:1 compression
Edelbrock heads, decked to 60cc's and CNC ported by Bill at Btr Performance
Cometic Head gaskets
Custom Cams Competion Hydraulic roller cam spec'd by Bill at BTR dur @ .050 245/248, lift .561/.580 106 intake centerline
Competion Cams matching roller lifters
Competion Cams dual valve springs for Hyd roller cam
Competion Cams custom length 3/8" push rods
Harland Sharp 1.7 roller rockers (makes valve lift .597/.618)
BTR double roller timing chain
OPP Cam Button w/roller bearing
ATI super dampner balancer
ATI flyweel
Edelbrock victor intake, heavily ported by Bill at Btr and gasket matched
1000cfm FAST fuel injection system Ez-EFI
Melling high volume oil pump
Moroso 7 qt oil pan
BTR backgrooved cam bearings, oil hole at the 4 o'clock postition
Clevite main and rod bearings. Main clearance .035" Rod clearnace .003"
DUI HEI distributor
CSR electric water pump
Summit Mini stater
MSD 10.5mm spark plug wires
MSD 6al Igntition
NGK spark plugs
Hooker Super Comp 1-3/4" coated headers with elctronic exhaust cutouts
3" exhaust to x-pipe, to 3" Flowmaster Super 40 series mufflers, to 3-1/2 dumps
Hoping for 550 + hp and 500 + tq
Should be firing up in the next month or so.......
ATI flyweel
Moroso 7 qt oil pan
DUI HEI distributor
Summit Mini stater
MSD 6al Igntition
NGK spark plugs
