There is a guy running similar specs, I believe stock Edelbrock's running high 10's in a 87 442. What trans and rear end? What rad are you running? I need to get my 403 pulled, my stroker build will happen eventually, I want it done right. I am stripping my 94 4x4 with the Olds 350. Taking the TBI out and putting it in the Cutlass. Getting a 700 cfm bored TB and may even use the 4L60E. Just need to figure a cheap effective way to refresh the 350. The 307 heads make decent compression easy but don't flow. I also have #8's and 4A heads, may use the 2" intake in the #8's, bowl work and Speed Pro standard forged flat tops. I think the low cranking compression is why my car was slow. Shooting for 180 psi this time. I want low 9's in the 1/8 with this temporary motor. A LS makes way more sense. 6 bolt mains and factory heads that flow 320 cfm go a long way. The sbc doesn't have any advantage over a SBO except plentiful and cheaper parts.
