my 79 monte
ducky_1978
13
piqua,ohio
just started putting her back together. cut down a 12 bolt to fit with 1978 trans am disc brakes.had to make a new set of rear upper arms. did the caprice spindle swap up front . had to make front upper arms cause ball joint angle was all messed up because of car sits so low.got airride on front and back.
What kind of motor and trans are you thinking about putting in it? Is that 12 bolt stock measurements or are you going to mini tub it? Looks pretty cool in the front being that low. Those wheels look awesome on third Gen Monte's . Are you going to leave it white or paint it another color? :? :?: 😀
building a smal block not sure what size.but going with a blow thru turbo set up and 4 speed muncie.12 bolt is stock measurements cut it down 1 5/8 a side to be right lenght. that is primer on car now going with good old black hard to go wrong with that.
got frame blasted ,painted and now i'm trying to put it back together
Looks very good! Keep up the good work!!!
got front rotors and brakes on today . how to get rear end together and in sunday.
