Hi I am Ken G, thought I would start a thread for my Gbody project.
I recently acquired an 83 Olds Cutlass (Supreme?) with a cracked-block V6 in it (see the newb forum). I have a Buick 231 turbo6 in the garage from maybe 1980 and I plan to swap it in.
I suffered thru the DMV today and got plates for the Olds, so now I am on to the Engine.
The turbo6 was "supposed" to run, but when I bought it it wouldnt start....I managed to knock the price down accordingly. It turns free. I am thinking at minimum a regasket and cleanup. I will swap some things from the 83 cracked V6 like the HEI, maybe alternator.....Not sure If I will try to keep the AC or delete it. May need the room for the exhaust pipes.
before I tear it down further I am going to add a starter on the stand and do a compression check. Depending on the results I may do a re-ring.
I got some casting numbers for the block (1381623) the heads on the engine (B1257661) and the spare set of heads (B1358676R) ******EDIT: block codes to a 1967 Dauntless 225 V6/jeep , also the spare 676 heaads. The 661 heads appear to be early 3.8L v6 heads. OH and the manifolds code to a 1978 turbo setup while the carb is a 1980 turbo carb*************
The block was "supposedly from 1967. One of the sets of heads is "supposed" to be a set of GN heads. Any help with ID on these numbers will be appreciated.****see edit above****
So that is the start of the project - get the turbo 6 cleaned up and swapped in - and the car on the road. Then I will move on to the interior and exterior.
Some pics attached:
Some pics attached:
