I cut the AIR pump part of the power steering bracket off and am keeping the rest of the bracket and P.steer assembly. Got it fitted up today.
I am keeping the Olds 70A alternator, but have eliminated the AC/Alt aluminum combo bracket in favor of an oldschool aluminum Buick Non-AC lower bracket. I cut two inches out of a Buick 350 upper Alternator bracket arm and welded it back together, hammered it flat, and it fits great so the Alternator is good to go.
Installed and torqued the turbo and plenum to the intake. Plugged the EGR manifold and reinstalled it.
I need to go to the auto parts store for an oil line for the turbo, some fuel line for the carb, misc pipethread adapters for the temp sending unit, heater hose etc. But I have the routing planned out.
Once I get the wire harness, oil line and fuel line situated correctly, I will put the alternator back on and start adding pulleys etc to the front of the engine.
I have to figure something out for the distributor - I have the CCC HET dist from the olds, I have a non computer V8 pertronics HEI or I have a simple points V6 dist. I think I want to combine the Olds HEI and the Pertronics HEI pieces to make a non computer 6cyl HEI but I dunno. The engine harness is set up for HEI though.
Another Question - I used the flexplate from the Olds V6. should I use the balancer from the Olds V6 or should I stick with the original from the 225?
getting much closer now. Eager to get it DONE. Maybe on fathers day I will get some "freetime" at long last hehheh
pics soon
edit: I shouls probable replace that lower radiator hose as well while everything is out of the way.
