Well, I've had the car for almost a year now. I haven't really posted much about it, but it is getting close to being done so I figured I would share.
Background. I bought the car with the sbc already built and installed. I took on the body work and paint myself. I also have a running VIN 9 with it as well. Here are specs on the engine and some pics of the car. enjoy!
1986 Oldsmobile Cutlass 442, less than 100k miles on body, around 1500 miles on chevy 350, around 3000 miles on 200-4r trans, sunroof car, brand new headliner
Engine chevy 350 .060
eagle crank, rods, speed pro pistons, sealed power rings
clevite 77 bearings
comp cams cam 270h, 270 duration, 470 lift
comp cams lifters, hardened one piece push rods
pete jackson noisey gear drive
melling oil pump, oil drive
arp main studs, head bolts, rod bolts
Chevy double hump heads casting 3890462 dates D207 (April 20, 1967) and D217 (April 21, 1967), ported, polished, 2.02I, 1.60E, hardened seats, screw in studs, guide plates
harland sharp roller rockers 1.5
summit stage 3 intake (edelbrock rpm air gap)
barry grant speed demon 650 electric choke, vacuum secondaries
hei dist, vacuum advance
polished aluminum valve covers
chrome aluminum pcv and breather
new oil pan and front cover
aluminum high volume water pump, high volume t-stat
holley mechanical fuel pump
heddman long tube headers
2.5" pipe, h-pipe
flowmaster 40 delta flows
aluminum radiator
2 electric fans
Trans rebuilt 200-4r, 1800-1900 stall
new clutches, band, seals, washers, bearings, sun gear, pump vane rings, stator shaft
valvebody calibration, firmer springs, nice firm shifts
bowtieoverdrives tv made ez throttle valve kit
Autometer sport oil pressure, water temp, volt, and fuel
First bought by prior owner, less engine
SBC that was built for it
After SBC intalled and still before I bought it. Looked very nice!
After I bought and started to prep for paint....The way I bought the car was nice, but it could use a fresh paint job. I started sanding the passenger door and it had bondo all over it. So I replaced the door with another, much straighter one.
clevite 77 bearings
2.5" pipe, h-pipe
aluminum radiator
2 electric fans
