my bolt on wilwood rear disc brake setup (7.5 rear)
91hrdbdy
132
2
41
so ive done the front brakes with Wilwood 12.19 rotors and 4 pistons calipers and i wanted the rear to match called Wilwood they said they don't have any thing for the 7.5 okay went to speedway not 7.5 setups that will work with Wilwood calipers. summit same thing.
well i made the first kit that is a bolt on and uses a Dynalite 4 piston caliber and a 11.5" rotor. here is this kit and here is the installed product your thoughts would be great. it doesn't require any modifications to the axle and a minor re-bending of the brake line to mate up to the Wilwood caliper.
installed
Do you have any other pictures of how the caliper was mounted?
here are some more pictures.
its a complete bolt on kit and it only requires the end user to drill out and tap 2 holes to 5/16x20 it can be done with simple hand tools and a basic home drill. cake work total install time should be around 1.5 to 2 hrs depending how skilled you are and the final product will be all grade 8 hardware. so let me ask would any one be willing to purchase some thing like this?
for a price range around 500.00 everything included or a brackets,rotors,hardware everything less calipers and pads for about 275.00 i"m thinking of offering this option as these calipers go on Ebay all the time for any ware form 75.00 to 150.00 a pair and that over half what i can buy them at.
I just mocked this up for the photo to show how it's mounted
many props to you for thinking outside the box. How do you plan to get around the parking brake issue ?
