my drive train set up
krazykyle
283
355 chevy ati 3800 stall 4.56 posi msd 6a box,distributor#8460 blaster 2 coil msd 8.8 black wires autometer gauges oil,water temp,fuel with isolator autometer tach with shift light worked 750 holley dp,holley regulator & holley blue series fuel pump fram canister fuel filter rci 16 gallon fuel cell with sending unit 1/2 alum line with #8 braided lones,earl's & aeroquipe edelbrock old style torker intake block paralell decked & line bore .30 over manley 10.5:1 flat top pistons,steel crank.pink rods assembly balanced to 8000 rpms canton 7 qt deep oil pan moroso high volume oil pump reed hydraulic camshaft special grind rhoads high intensity lifters crane roller rockers rare #441 casting heads off record holding stocker manley stainless valves 3 angle valve job,screw in studs cyclone headers s/s locking bolts sfi certified fly wheel ati tree master 10 inch 3800 stall fresh turbo 350 with turbo action cheetah series manual valve body new drive shaft incl yoke tube & u joint 67 chevelle wagon 10 bolt 8.2 ring gear 4.56 new carrier and axle bearings all spring and clutches long wheel studs center line drag 15x8.5 m/t l 60 t bone tires and 15x3 m/t front runners along with hurst pro matic 2 shifter mid 12's also i went with umi proformance rear end kit to center up the rear end all in my 83 cutlass :twisted:
Sounds like a sweet lil drag car. I looked in your album but it did not show any pics. Is this is the Cutlass on your avatar? With 10.5-1 its probably a pump gas set up do you prey at the local stop lights? :rofl: 12s are good. 12 what at what mph? If you don't mind me asking do you know about how much it would cost to set a drivetrain like this up?
i can not tell a lie about 3000.00 dollars.my buddy need money real bad and i gave 2000.00 for his 79 olds that the drive train came in and put about another 1000.00 into my 83.i hit the lotto that day
