My LED tailights
Rockstar
269
Tampa,Fl
I used LED trailer lights from Pepboys (2 per side) took out the LED cuircut board then seperated my stock taillights and set the led boards in the housing then screwed them to the back of the housing. Reglued the housing together wired it up then wa la!
thats impressive
Everything worked as normal, other than the fast blinking which can easily be fixed. I also wired them directly to the factory harness. The pic was takin with the parking lights on the brake lights were hella bright.
you should put up some more pics of them, like from farther back
