MY RIGHT TURN SIGNAL IS FLASHING TOO FAST HELP!! 85 GP
tklan22
19
38
ATL
I TRIED REPLACING ALL OF THE BULBS ON THE RIGHT SIDE & THE ONE THAT DOESNT WORK IS ON THE LOWER REAR FINDER...DO I NEED TO REPLACE THIS PIECE??
That bulb don't blink so i dont think it would cause the fast flash. I had a couple of those side bulbs out on my car & it didn't cause that. Maybe you need a new flasher relay.... I take that back because I believe it would flash fast both ways if it was the little relay unit going bad... You may have a shortage somewhere thats throwing the resistance off & causing it or maybe it is that bulb that's causing it
tc1959 said:
Just pull the bulb straight out of the socket,and replace with a #194
I DID THAT ALREADY
tklan22 said:
I DID THAT ALREADY
Check for power in the socket with a test light,and check the ground for that socket.
