Hi,
Ive been away from my project for a while and I am forgetting things. The car has a 403 with a 2004r and the stock 7.5 inch 2.49 rear. I kept the CCC Carb set up. However I am running headers and never installed my O2 sensor which I intend to do. The short story is I got hurt went out on disability from work, during that time I dropped my daily driver off to get repainted. It should have been a week but for what ever reason they've had the car 6 weeks I don't want to rush them because then the car will probably come out terrible. But I go back to work on next wed so I need to put my project car on the road to go back to work. The Cutlass has the check engine light on because the O2 sensor isn't in, so Im guessing its in limp home mode. Would that keep my torque converter from locking? I like the idea of it staying in tune and getting some mpg so Id like to keep the CCC system. Worst case Scenario I did buy a RPM activated switch from MSD I was thinking of setting it to 1800 RPM and hooking it to the lock up solenoid and wiring a relay inline so when I hit the brakes it unlocks, then use a regular carb and distributor.
