Mysterious wiring connectors.....
pic 1 top connector is for back up lights, bottom connector is to tell the computer if your in park/neutral or not
pic 2 may be for rear window defogger sw or relay
pic 3 is one of the two connectors for ignition sw
pic 4 is for cruise deactivation sw at brake pedal
pic 5 is for computer communication, dlc
pic 6 i'm not sure, it has a white wire, possibly for courtesy lights?
pic 7 is head light dimmer sw on column
pic 8 is for trunk release
Reactions: -83MONTESS-
pic 6, is that a white wire? or is it gray?
Alright guys thanks for the help I got everything put together and hooked up for the most part but theres a few connectors left that I can't find a home for. Any help is appreciated....
Yea I got the computer port one figured out. Shoulda known with the bolt holes on each end. The last 5 I recently posted are the ones that have me stumped. Especially the tiny 3 wire one that comes out of the bottom of the steering column. Any ideas?
of the new pics,
pic 1 connects to rear window defogger
pic 2 is for rear defogger relay, black part slides onto and lock to top of fuse block, brown connector connects to fuse block
pic 3 is from cruise sw on column and connects to pic 5
pic 4, if hot or has power all the time, it probably powers up the power seat or power locks, if the key has to be turned on, then it may be for power windows
pic 5, see pic 3
of the new pics,
pic 5, see pic 3
Ok awesome thanks for the help. Out of all of those the only one I will worry about is the one in pic 4.
i hope others will help us out on pic 4. i think power seat is orange with black stripe.
