Need help wiring stereo system properly
since your subs are dual 4 ohm, you cant wire them to 2 ohms. its just how the ohm law works, if you want to wire to the lowest ohm possible on those subs, which is 1 ohm, getting an amp thats 1 ohm stable is the only way, and i would reccomend a monoblock amp if you wanted to get another one, which is a single channel just for subwoofers
link to subs?
http://www.pioneerelectronics.com/PUSA/Car/Subwoofers/Champion+Series/TS-W1007D2|D4
They are the D4 version
Now for my last question...If I hook my subs up now to existing amp. I will be using CH3. If I bridge the voice coils of each sub should I be running positive and negative from each sub to the amp and stacking them, meaning I will have 2 positives and 2 negatives going to the CH3 terminal. Or should I be running a positive and negative to the first sub and then running the positive and negative from one sub to the other?
