I recently purchased and 84 buick estate wagon. Car had been setting since 1993. It had 3 bad place in rear brake line and one bad wheel cylinder. I replaced all brake lines and wheel cylinder. I also replaced master cylinder. First master cylinder was bad (cheap chinese from auto zone). second master seemed fine but when i turned on car brakes went away(pedal sinks all the way to floor slowly. Went to autozone got another and new valve for brake booster. Problem is the same again. Went to orielys and got a different brand of master , still pedal sinks. I have probably run 2 gallons worth of fluid through these lines but just in case i bought a pheonix reverse bleeder. Still same problem.
list of things done
1. new line
2. 3 news masters all bench bleed
3. fixed leaking wheel cylinder
4. can find no leaks
5. vacuum is good to booster
6. brakes get good pressure at all 4 wheels
7. regular bleed and reverse bleed seems like a hundred times.
list of things done
1. new line
