I recently pulled my engine (SBC 350 block # 3970010)out of one Cutlass & put it in my other one. I took the cap off but I broke the rotor when & was pulling it out. The distributor was getting caught up so I pulled it out too. Later I found out a wire in the distributor was broken so i dropped another one in exactly how I pulled the other one out. Once I got everything wired up I tried to start it & it wouldn't fire up. After that didn't work i moved the distributor counter clockwise & tried it again now it sounds like it want to fire up but I couldn't turn the distributor anymore. I ended up moving all the plug wires around 1 spot counter clockwise & it fired up but that is wrong because now the # 8 wire is in the #1 spot
I'm sure I had it wired just like the diagram before I took everything apart & I know i dropped the new distributor back in the same spot that the old one came out of so I don't know whats going on here... Please help!!!
