I just bought a brand new road rage capacitor rated for 1 farred 20/24. I bought it because my system would kick off once I used my headlights or turned up to a certain volume. The system consists of 2 12in. dual subs with a Rockford Fosgate 2400w Punch amp (2 channel). Technically the amp only puts out 800w on one channel and 400w to each one of my subs. Problem is I have no idea on what gauge wire to use and how to wire it up. The ground is simple, its trying to wire up the main power line to the capacitor is what I can't figure out. The wiring diagram says "run a wire directly from the battery to the positive terminal of the capacitor then run a second wire from the terminal of the capacitor to the amp". Question is how do you rig up two wires like that and am I supposed to use 4 gauge wire like I have throughout the system?
